Deletes the PVLAN framework with the specified name.
| name | Specifies the name of the PVLAN to be deleted. |
N/A.
The PVLAN is a framework that links network and subscriber VLANs; it is not an actual VLAN.
This command deletes the PVLAN framework, but it does not delete the associated VLANs. If the ports in the network VLAN were set to translate, they are changed to tagged.
The following example deletes the PVLAN named "companyx":
delete private-vlan companyx
This command is available on all platforms that support the Private VLAN feature. For features and the platforms that support them, see the Switch Engine v33.1.1 Licensing Guide document.
